yagyu
Feb 23, 2021Aspirant
GS716Tv3 Ha SETUP
Hi! I want to set up HA with fortigate firewalls like: switch - fw - switch internet ---> | | | --> LAN sw...
JohnC_V
Feb 24, 2021NETGEAR Employee Retired
Welcome to our community! :)
May I know what do you want to achieve here? The firewall should be the one that is connected to the internet first before the switch. Do you have a multi-WAN setup?
John
NETGEAR Community Team
yagyu
Feb 26, 2021Aspirant
Hi John
I want to have redundant firewalls in case one dies it's not a SPOF.
To achieve this I need a switch to aggregate my 2 firewalls and 1 internet circuit line.
Just like this contraption:
To go one better I want 2 switches in HA too if I can.
Matt
- schumakuFeb 27, 2021Guru - Experienced User
yagyu wrote:To go one better I want 2 switches in HA too if I can.
And a little assistant changing the link to the Internet line in the failure case?
This is what we implement in basic HA environments - you can add two additional switches on the Internet side of you desire:
