jeon
Mar 24, 2021Aspirant
GS716Tv3 Rate Limiting
Hello, We recently purchased GS716Tv3 and are conducting tests. One of the test items is to set port based ingress and egress rate limits. The specification sheet shows that this is possible with t...
schumaku
Mar 24, 2021Guru - Experienced User
jeon wrote:However, it doesn't work the way we want it to.
Tell us a little bit more what you expect, what you configured, and what the unexpected result was.
- jeonMar 29, 2021Aspirant
Hi, schumaku
Thank you for your interest in my question, and I'm sorry for the delay.I just found the manual below in Netgear Community.
Because I needed 100Mbps of Shaping Rate,
I tested scenario 2 by referring to the manual.https://drive.google.com/file/d/0B4PuVEYxkQ5oTW1lcDJpYm1XVlE/view
See Test Configuration Diagram and Results
However, the results are not working as written in the manual.
And according to the manual, GS748Tv4, a similar model to the GS716Tv3, seems to say that both Ingree and Egress are possible, but the speed of Ingree and Egress is quite different.
Did I misinterpret something?
