slaske
Jul 09, 2019Aspirant
GS724T Firmware upgrade - Need 2.05.02 Smart Wizard on CD v.2.0, v2.1
Hi, I need a download link for 2.05.02 Smart Wizard on CD v.2.0, v2.1 since this is needed to upgrade the firmware initially. Tried searching the web but I can't find any link on negear.com or Goo...
- Jul 10, 2019
Finally found it in this post.
Direct link
http://www.downloads.netgear.com/files/GDC/GS724Tv1/Smartwizard%20Utility%20Version%202.5.3.zip
schumaku
Jul 09, 2019Guru - Experienced User
Would be great if Netgear would ad the older versions of the utility to the downloads https://www.netgear.com/support/product/Smart%20Wizard%20Utility.aspx ... Christian_R please take care.
