glueball
Apr 09, 2018Aspirant
GS724T: hierarchical Inter-VLAN Routing capabilities?
Hallo, I want to put a managed switch with VLANs behind my internet-router and wonder if the GS724T could be the right choice. The requirement is some hierarchical inter-VLAN-Routing: Lets sa...
- Apr 21, 2018
Hallo DaneA,
thanks for your friendly and detailed answer.
I did some reading and think I need some more sophisticated L3-capabilities like SPI or reflexive ACLs between the VLANs.
It might be easier to take a pure L2 switch and some real router.
Thanks again,
kind regards,
Jörg
DaneA
Apr 10, 2018NETGEAR Employee Retired
Hi glueball,
Welcome to the community! :)
The GS724Tv4 is categorized as a Layer 2 Smart Switch and not a Fully Managed Switch. With regard to Inter-VLAN Routing, let me share the articles below and these might help as reference guides:
VLAN Routing on Smart Switches
VLAN Routing on a NETGEAR Smart Switch
The question is if the GS724T brings the necessary internal L3-possibilites for the described setup.
The GS724Tv4 (v = version) has Layer 3 Lite features only. As reference, kindly check its data sheet here.
If you want a Layer 3 switch, I recommend you the NETGEAR Fully Managed Switches like the M4100 series and M4300 series models. Kindly check the link below to know more:
DaneA
NETGEAR Community Team
- DaneAApr 15, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- glueballApr 21, 2018Aspirant
Hallo DaneA,
Thanks again,
kind regards,
Jörg
