vguna's avatar
vguna
Guide
Mar 09, 2019
GS724TP-200EUS questions
Hey.   I'm looking to buy that switch for my new home and I wanted to ask some questions upfront instead of having to return it if it doesn't fit my requirements. Sadly there are ambigious answer...
  • DaneA's avatar
    Mar 11, 2019
    Hi vguna,
    Welcome to the community! :)
    The GS724TP-200EUS is the product order code of the GS724TPv2 switch in Europe and UK.
    - Does this switch support disabling PoE ports via SNMP like described here for the 48 port version?:
    https://community.netgear.com/t5/Smart-Plus-Click-Switches/Switch-GS728TP-POE-Admin-enable-disable-via-SNMP/m-p/1574183
    I'm aiming to "reset" PoE devices automatically using scripting and an SNMP agent.
    I believe this is also possible for the GS724TPv2.
    - Does the switch support IGMP v3, which is needed for some german TV streaming offers like Telekom Entertain etc.
    Yes, the GS724TPv2 switch supports IGMP Snooping v3.  As reference, kindly read page 5 of the GS724TPv2 Data Sheet here.
    - Does somebody know, what is the power consumption of that switch when no devices are connected? And how many watts are approx. added per non-PoE connected port/device?
    As per page 8 of the GS724TPv2 Data Sheet here, the Maximum Power Consumption (worst case, all ports used, full PoE, line-rate traffic) is 228.53W while the Maximum Power Consumption without PoE (worst case, all ports used, full PoE, line-rate traffic) is 21.62W.
    - The fan in this model has been reported to be very loud. Is this still an issue with the recent v2 version?
    As far as I have checked my resources, the GS724TPv2 switch meets the specifications when measured in noise laboratory following the ANSI strict requirements.  If ever the fan produces loud noise which is not normal, then it could be a hardware fault, an RMA can be process.
    - Is Amazon considered an "authorized reseller" in terms of ProSafe Lifetime Warranty program that (hopefully) applies to that switch as well?
    Amazon is one of the Authorized NETGEAR Resellers.  As reference, check this link.  As for the warranty, even though the NETGEAR device is purchased from Amazon, it still follows what is indicated on the article here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
