Michelle911's avatar
Michelle911
GS724TPP and AP issue
I have two EnGenius EWS377AP's connected to the GS724TPP switch using POE 802.3at. I am using VLAN's, but not a management VLAN and no issues there.   I cannot ping or log in to either one from the...
  • schumaku's avatar
    schumaku
    Dec 28, 2020
    Possible workaround to the issue - I suspect the AP does go all tagged on PoE why ever (compatibility to the makers wireless controller?) - would be to change the "base VLAN" from untaged to tagged for both the AP management and the SSID assigned on both ends.
ProSupport for Business
