Michelle911
Dec 26, 2020Aspirant
GS724TPP and AP issue
I have two EnGenius EWS377AP's connected to the GS724TPP switch using POE 802.3at. I am using VLAN's, but not a management VLAN and no issues there. I cannot ping or log in to either one from the...
- Dec 28, 2020
Possible workaround to the issue - I suspect the AP does go all tagged on PoE why ever (compatibility to the makers wireless controller?) - would be to change the "base VLAN" from untaged to tagged for both the AP management and the SSID assigned on both ends.
schumaku
Dec 28, 2020Guru - Experienced User
Sorry Michelle911 ...
Michelle911 wrote:I use the same port whether or not I'm using an external power pack or the POE. I can ping the AP when using the external power, but not when using only POE.
...now I understand the second part of the initial message, too.
Must admit - completely buffed. As any other "...I am using VLAN's, but not a management VLAN and no issues there. ..." communication seems to be workable either way - have you talked to the AP maker already?
schumaku
