UserFriendlyTS
Dec 29, 2020Follower
GS724TPP Failed Audit due to Lighttpd Version
Routine audit showed our Netgear is running a version of Lighttpd that is affected by CVE-2014-2323, CVE-2014-2324. The audit wants verison 1.4.35 or later of Lighttpd. The switch is running firmware 2.0.2.6. I see that 2.0.2.8 is available, but the notes do not list that it upgrades Lighttpd. Can you tell me if Lighttpd is part of the firmware update for 2.0.2.8? If not, is there a way to update Lighttpd by itself?
Thank you,
Mark
1 Reply
Let audit check the vulnerable modules mod_mysql_vhost.c, mod_evhost.c, and mod_simple_vhost.c are part of the implementation. 8-))))
Change your audit company if they insist on version numbers.
