MadTom_T
Mar 05, 2019Aspirant
GS724TPS Inter-VLAN Routing ?
Hi
Can anyone advise if this switch support Inter-VLAN Routing.
If it does, how do I set it up.. if not what are my options ?
Thanks
Hi MadTom_T,
The GS724TPS does not support Inter-VLAN Routing. You will not find the term 'Inter-VLAN Routing' in the GS724TPS data sheet here and also in the GS724TPS user manual here.
If you need a smart switch that supports Inter-VLAN Routing, I recommend you the GC728XP. For more information about the GC728XP switch, kindly access its data sheet here.
Furthermore, access the link below and select the switch that matches your network requirements:
DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
Hi MadTom_T,
DaneA
