Arnaud_D
Dec 07, 2021Aspirant
GS724TPv2 - 2.0 Firmware
Good Morning (again) I have another firmware update question. This one is for GS724TPv2, all the one I have are in 1.1.50.39, the last firmware before 2.0 Existing configurations will be era...
schumaku
Dec 08, 2021Guru - Experienced User
Arnaud_D wrote:
Other thing : What does 'Access Limited features by going directly to local device login' means ? What does 'limited features' means ? I don't want to connect my switched to the internet, so if I don't do so I won't be able to fully manage my switch as I do now ?
The switches require registration with the v2 firmware update. This can be done by allowing internet or by an offline process by entering the registrtion key on the switch. FMI How do I find my NETGEAR registration key?
