TDSBL
Oct 08, 2021Aspirant
GS724TPv2 - Firmware 2.0.6.3: SFP Module AGM731F
All, I've recently upgraded the firmware only on my switches from 1.1.25 > 2.0.6.3 and all went well. I have not upgraded any of the MIB versions at this stage. Prior to the upgrade I had the AG...
schumaku
Oct 11, 2021Guru - Experienced User
No own experience on this model, however would you mind to try unplugging fiber and SFP, then replug on both ends?
- TDSBLOct 11, 2021Aspirant
schumaku thank you for your response and this was already tried but to no avail.
Any additional recommendations or comments would be advantageous.
- schumakuOct 11, 2021Guru - Experienced User
We need Netgear's switch engineering support here - not much left of what I can think of.
- DanioYNov 07, 2021NETGEAR Employee Retired
Hi There,
What's the fiber port setting in both switches? It should be auto negotiation by default.
If any side is not auto-negotiation enabled, please change it to auto-negotiation enabled and try again.
The othe way is to reset both switches to factory default and try again.
