TDSBL
Oct 08, 2021Aspirant
GS724TPv2 - Firmware 2.0.6.3: SFP Module AGM731F
All, I've recently upgraded the firmware only on my switches from 1.1.25 > 2.0.6.3 and all went well. I have not upgraded any of the MIB versions at this stage. Prior to the upgrade I had the AG...
schumaku
Oct 11, 2021Guru - Experienced User
No own experience on this model, however would you mind to try unplugging fiber and SFP, then replug on both ends?
TDSBL
Oct 11, 2021Aspirant
schumaku thank you for your response and this was already tried but to no avail.
Any additional recommendations or comments would be advantageous.
- schumakuOct 11, 2021Guru - Experienced User
We need Netgear's switch engineering support here - not much left of what I can think of.
- DanioYNov 07, 2021NETGEAR Employee Retired
Hi There,
What's the fiber port setting in both switches? It should be auto negotiation by default.
If any side is not auto-negotiation enabled, please change it to auto-negotiation enabled and try again.
The othe way is to reset both switches to factory default and try again.
