ShawnVInCA
Dec 11, 2020Follower
GS724TPv2 and XFinity Modem
Good evening. Newbie here. My old switch died and I purchased a GS724TPv2 for a replacement. I figured that I'd upgrade to something nicer but now I've gotten myself into a problem. Prev...
antinode
Dec 11, 2020Guru
> My old switch [...]
Not a very detailed description of that device.
> [...] the Xfinity modem [...]
> Model: GS724TPv2|24-Port Gigabit Ethernet PoE+ Smart Managed Pro
> Switch with 2 SFP Ports
A more appropriate forum:
https://community.netgear.com/t5/x/bd-p/business-smart-plus-click-switches
> I put the new switch in place and realized that it, too, had a DHCP
> server. [...]
I know nothing, but I'd bet a small sum that it's optional.
If your (unspecified) "My old switch" was stupid/unmanaged, and you
were happy with it, then a similarly simple switch might have been a
better choice as its replacement than one with a 400-page User Manual.
> [...] Do I just disable the DHCP server on the modem?
If your (unspecified) "the Xfinity modem" has a DHCP server, then I'd
guess that it's a modem+router, not a simple "modem".
If you're replacing a switch with no DHCP capability, then why not
disable the DHCP capability in the new switch? How many things would
you like to change at the same time?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read? Look for
"DHCP"?
schumaku
Dec 15, 2020Guru - Experienced User
At the risk of disappointing your troubleshooting: The GS724TPv2 does not have a DHCP server. It offers some DHCP Snooping, however this isn't enabled by default.
Was your unspecified old "switch" probably a router?
So I start to wonder if what you suspect coming from a magic DHCP server might be some 169.254.x.x ZeroConfig addresses?
Come-on antinode there are just 118 occurences of DHCP on the 400 pages 8-)
