WhalingCity
Sep 21, 2020Aspirant
GS724TPv2 Firmware and bootcode updates
I just purchased a brand new GS724TPv2 switch on 9/21/2020 and wanted to begin by updating it to the latest firmware, I am not only amazed at how old the firmware and boot code is on this unit, but ...
- Sep 22, 2020
Never mind, went back to the Netgear support site and found the V1.1.50.39 .rom firmware.
schumaku
Sep 22, 2020Guru - Experienced User
Appears you mix up firmware/downloads for the legacy GS724TP model (lauched about 14 years ago!!!) with the GS724TPv2. Strictly stick with the downloads for correct model and version.
If your's is a v2 start here for the conversion from a v1.1.x to v2 -> https://kb.netgear.com/000061525/GS724TPv2-GS724TPP-Firmware-Version-2-0-0-16
Once done you can continue with the current firmware, as of writing https://kb.netgear.com/000061912/GS724TPv2-GS724TPP-Firmware-Version-2-0-2-6
The process is purley Web (http) based. No nasty utilities, no tftp (while still possible).
- WhalingCitySep 22, 2020Aspirant
Thank you for the reply, did not realize that the GS724TP and GS724TPv2 were listed seperately. After downloaded both upgrade zip files, I noticed that the V2.0.0.16 download includes a .bix and a .img firmware image, but no .rom image as the HTTP Download instructions says it should. Which one should I use?
