WhalingCity
Sep 21, 2020Aspirant
GS724TPv2 Firmware and bootcode updates
I just purchased a brand new GS724TPv2 switch on 9/21/2020 and wanted to begin by updating it to the latest firmware, I am not only amazed at how old the firmware and boot code is on this unit, but ...
- Sep 22, 2020
Never mind, went back to the Netgear support site and found the V1.1.50.39 .rom firmware.
schumaku
Sep 22, 2020Guru - Experienced User
Appears you mix up firmware/downloads for the legacy GS724TP model (lauched about 14 years ago!!!) with the GS724TPv2. Strictly stick with the downloads for correct model and version.
If your's is a v2 start here for the conversion from a v1.1.x to v2 -> https://kb.netgear.com/000061525/GS724TPv2-GS724TPP-Firmware-Version-2-0-0-16
Once done you can continue with the current firmware, as of writing https://kb.netgear.com/000061912/GS724TPv2-GS724TPP-Firmware-Version-2-0-2-6
The process is purley Web (http) based. No nasty utilities, no tftp (while still possible).
WhalingCity
Sep 22, 2020Aspirant
Thank you for the reply, did not realize that the GS724TP and GS724TPv2 were listed seperately. After downloaded both upgrade zip files, I noticed that the V2.0.0.16 download includes a .bix and a .img firmware image, but no .rom image as the HTTP Download instructions says it should. Which one should I use?
- WhalingCitySep 22, 2020Aspirant
