ashjeaton's avatar
ashjeaton
GS724TPV2 tagged management VLAN not working
Hello Netgear Community,
We recently purchased another batch of GS724TPV2 which appear to be slightly newer than the last batch. They have a new login interface and can be Insight managed.
My issue is that I no longer seem able to use a tagged interface for the management VLAN. It does not reply to ping or connect via HTTPS unless I change it to untagged. Is this a intended change or am I doing something wrong?
The firmware version  is 2.0.6.3. Thanks.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi ashjeaton,
    Welcome to our community! :)
    Management VLAN can only be accessed if you are on the same VLAN. Technically, it cannot be accessed from a trunk port and can only be accessed via the untagged port.
    John
    NETGEAR Community Team
  • schumaku's avatar
    schumaku
    This looks OK to me, especially considering the cutomer already has similar set-ups with an earlier hardware or model version.
    Of course the switch management VLAN can be reached from the same switch (a tagged access port), over a VLAN trunk, .... JohnC_V
ProSupport for Business
