evb
Feb 26, 2019Guide
GS724Tv3 and GS724Tv4 possible on one network?
I was searching for a second switch to extend my existing switch GS724Tv3.
On following site: https://support.biamp.com/Tesira/AVB/Identifying_Netgear_GS724T_switch_version, I found following infor...
- Mar 06, 2019
Sure it is possible, like any other industry standard switches. Kind of an obsolete question - misguided by a 3rd part vendor with specific code included on one of these models.
schumaku
Feb 28, 2019Guru - Experienced User
That must be something specific to the add-on software/firmware specific by the site your reference is coming from.
evb
Feb 28, 2019Guide
Okay.
So if used normally in a network, these two types of switches can coexist and work together?
I have one v3 and wanted to buy a second switch to extend the connections, but because the v3 is deprecated, I must go for a v4.
Wanted to be sure that the setup with a v3 and v4 will work.
- evbMar 06, 2019Guide
Nobody can confirm this?
Can a v3 and v4 cooperate together in one network?
- schumakuMar 06, 2019Guru - Experienced User
