str1k3r
Nov 02, 2016Aspirant
GS724tv3 fails to boot after firmware update
Hi, I performed a firmware update on our two GS724Tv3 switches nightly, first one went through without problem, the second now fails to boot.. Funny that the situation is exactly the same ...
- Nov 16, 2016
Since an online replacement has been processed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future! :)
DaneA
NETGEAR Community Team
DaneA
Nov 16, 2016NETGEAR Employee Retired
DaneA
