Bimmer
Dec 04, 2017Aspirant
gs724tv4 bricked?
Hi, I tried to upgrade my firmware. That wend wrong, so I now am stuck with a bricked switch. Bricked as in: it does show the leds blinking, I cannot access it via smartcontrolcenter, nor can I ...
- Dec 04, 2017
OK,
I turned the power off for half an hour and to my surprise it came up again....
Problem solved... for now :)
Cheers!
Ruud
Bimmer
OK,
Cheers!
Ruud
- JohnC_VDec 05, 2017NETGEAR Employee Retired
Hi Bimmer,
Welcome to our community!
It seems that you were still able to work it out by just turning it off for half an hour. Just in case that the switch would not work anymore, you may just create a chat / case online on NETGEAR support and also be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification. If ever the device is still under warranty, an online replacement will be provided.
