mipro
Jun 26, 2019Follower
GS724Tv4 sntp configuration problem
Hi all I have the problem with enabling SNTP on all of mine 8 Switches GS724Tv4. I have added an SNTP server on System>Management>Time>SNTP Server Configuration added gateway address as you c...
Catch-21
Jul 17, 2022Initiate
I eventually sorted it out using this post. There's a bug in the UI where if you hit Apply it DOES take and process the change from local to SNTP, it just doesn't immediately show it. Once it goes out to get the time for the 1st time depending on polling interval, it will then update the UI too.
