martinezjr
Jan 31, 2018Aspirant
GS724v4 VLAN issue
So, I hate to beat a dead horse, but I can not get this to work.... I have connected, configured, reset, . . . over and over, searched the internet, searched this forum, read most(if not all) regardi...
- Feb 01, 2018
Well, it seems that like flipfl0p, it is just working now. I just did a factory reset, re-configure as stated below, ... the only thing that I did different was under System->Services->DHCP Snooping->Global Config, was to disable MAC Address Validation. I then reboot everything including the router(s) and it worked.
martinezjr
Feb 01, 2018Aspirant
JohnC_V
Feb 02, 2018NETGEAR Employee Retired
Hi martinezjr,
Welcome to our community!
Thank you for sharing the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
