tsalman
Nov 05, 2018Tutor
GS728TP and GS752TP Visio Stencil
Where can I get a copy of the visio stencils for the GS728TP and GS752TP switches? They are not in the downloadable Netgear VSS file.
JohnC_V
Nov 05, 2018NETGEAR Employee Retired
Hi tsalman,
Stencils are not provided by free from NETGEAR. Our visio stencil technology partner Netzoom(Altima) recently changed its link and we are in the process of updating our website.You may get those stencils here.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
tsalman
Nov 05, 2018Tutor
The stencils for the GS728TP and GS752TP are not in that VSS file downloadable from NetZoom.
- tsalmanNov 05, 2018Tutor
Nevermind. I created my own GS728TP and GS752TP Masters. If anyone else is looking for these two and don't want to edit like I did, go ahead and contact me. I'd attach the file here, but the community won't allow me to attach .vssx files... go figure.
- bkness03Nov 28, 2018Aspirant
I see that you have the same exact troubles as me. I would love to get a copy of your GS728TP visio stencil.
If there are any that you need, please don't hesitate to ask, I may have or already created them.
- SteveHarveyAug 07, 2019Initiate
- TylerHooverDec 13, 2018Aspirant
I could use that GS728TP stencil if you still have it handy.
Thanks,
Tyler
- mbskeystoneApr 26, 2019Aspirant
I would love to get those stencils from you. I'm finally putting together Visio drawings for several of our installations!
Thanks!
