LinwoodF
Jul 02, 2024Aspirant
GS728TPv2 doesn't seem to support LLDP-Mib
I have a GS728TPv2 that I found does not appear to support LLDP-MIB. It gives OID not found and also doesn't list it on the MIB page. I THOUGHT it did, I thought I had tried this some time ago....
- Jul 04, 2024
The older Smart Managed Switches offered various OID subsets, like some proprietary/private MIB as well as some less common ISO ones like iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).
If it's not listed, it's not supported 8-/
LinwoodF
Jul 04, 2024Aspirant
"Not listed, not supported" ... ok. What I expected if not hoped, was hoping I missed a setting.
It's mildly strange it has broad SNMP support, supports LLDP, but they didn't include the LLDP MIB for SNMP, especially when on a less managed, much much older switch (MUCH older) it works beautifully.
schumaku
Jul 04, 2024Guru - Experienced User
Perfectly correct. My first impression this might be a private MIB extension proofed wrong.
Netgear also failed to return the NETGEAR-BOXSERVICES-PRIVATE-MIB on newer Smart Managed Switch models for continuity...
Iphie_C please.
