ahmeali's avatar
ahmeali
Follower
Mar 12, 2021
GS728TPV2 MAC ACL problems Firmware Version V6.0.6.2
Good morning every one ,
I have the smart managed Switch GS728TPV2, for Security , i want to enable only the company device to be able to access the network .
I tried to do this with MAC ACL based on source MAC
the configuration looks like where XX is the Mac of the laptops ,pc..etc
sequence 1 permit XX:XX:XX:XX:X:XX/00:00:00:00:00:00 any vlan any cos any ethtype any asq any mirror any redirect any matchEvery 0 logging 0 ethKey any
sequence 2 permit XX:XX:XX:XX:X:XX/00:00:00:00:00:00 any vlan any cos any ethtype any asq any mirror any redirect any matchEvery 0 logging 0 ethKey any
sequence 3 permit XX:XX:XX:XX:X:XX/00:00:00:00:00:00 any vlan any cos any ethtype any asq any mirror any redirect any matchEvery 0 logging 0 ethKey any
and then i bind to All the ports like this (example not to make it toong )
interface g1
acl bind seq 1 "LAN"
upto 4 seuences it work ,
if i connect usb to ethernet dongle not in the mac in the list it doesn't get access to the netowrk and i tried on all port .
Problem However , if added more sequence than this 4 (even just one more sequence so in total 5 rules) ( my final list should be 30 sequence)  and i test again , it works on the first 3 port but all other ports it gets the connection and can ping the resources inside which souldn't be the case
am sure i binded on all ports .
so can you tell me what am doing wrong ? appreciate the help as i have been in circle for days aorund this problem .
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    ahmeali,
    Just found out that you have an ongoing support ticket with NETGEAR Support.  You may post here the progress of it.
    DaneA
    NETGEAR Community Team
ProSupport for Business
