LinwoodF
Jul 02, 2024Aspirant
GS728TPv2 doesn't seem to support LLDP-Mib
I have a GS728TPv2 that I found does not appear to support LLDP-MIB. It gives OID not found and also doesn't list it on the MIB page.
I THOUGHT it did, I thought I had tried this some time ago. Not certain.
I have a couple of very old GS108Tv2 that work just time. VERY old. Much older than this. So it seems odd the GS728TPv2 doesn't support it.
Is that correct? Is there any off/on switch for MIB's, or a way to load support for them?
Did this perhaps get removed in a prior firmware update (I am one back from current and current release notes indicate no issues, I am on 6.0.10.20.
Linwood
The older Smart Managed Switches offered various OID subsets, like some proprietary/private MIB as well as some less common ISO ones like iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).
If it's not listed, it's not supported 8-/
- LinwoodFAspirant
"Not listed, not supported" ... ok. What I expected if not hoped, was hoping I missed a setting.
It's mildly strange it has broad SNMP support, supports LLDP, but they didn't include the LLDP MIB for SNMP, especially when on a less managed, much much older switch (MUCH older) it works beautifully.
Perfectly correct. My first impression this might be a private MIB extension proofed wrong.
Netgear also failed to return the NETGEAR-BOXSERVICES-PRIVATE-MIB on newer Smart Managed Switch models for continuity...
Iphie_C please.
