Mariuszing
Nov 30, 2020Follower
GS728TXP with 10GBASE-T as normal Port
Hello, Is it possible to use on GS728TXP the 10GBASE-T as normal port for example on a Notebook with 10GBASE-T ethernet port? The other 10GBASE-T port is remainig for another computer. The both 10G...
schumaku
Nov 30, 2020Guru - Experienced User
In the S3300, the four uplink ports can work in either Stacking mode or in Ethernet mode.
In the Device view:
• By default those ports are in Stacking mode, and their color is gray.
• When these ports are configured in Ethernet mode, then their color is blank (unless connected).
System > Stacking > Advanced > Stack-port Configuration
Ensure you select the correct unit (if stacked) and port to change the port from the default Stacking mode to the Ethernet mode.
FMI: S3300 Smart Managed Pro Switch User Manual p.25 and p.80 ff.
