cwagz
Aug 20, 2022Star
Replaced GS724Tv4 with GS728TXP and AirPrint Will No Longer Work
Hi,
I had a working configuration with IGMP snooping enabled per directions found in the forum. All mdns functions on the network were working. Yesterday I replaced my GS724Tv4 with a GS728TXP running firmware 6.6.4.28.
I configured IGMP Snooping, Querier and router as I have always. Airprint is no longer working on wired printers connected to this switch.
I have 3 WAC510 Access points connected to a MS510TXUP. The MS510TXUP is connected via SFP+ to the GS728TXP. The network is configured just like I had it when AirPrint was working the only change is the GS724Tv4 was replaced with a GS728TXP.
Is there an issue with IGMP snooping on the GS728TXP and current firmware?
Quick update. I was provided with a pre-release firmware for testing. The firmware fixes the issue I was encountering. I assume it will be released publicly soon.
Just a quick follow-up.
Disabling IGMP snooping status on just the GS728TXP immediately brings the printer back on AirPrint. No changes needed on the other switches or wireless access points that I am using to print through.
I found this as a known issue for the GC728XP:
When either the IGMP or MLD snooping is enabled on a VLAN or globally, unknown multicast packets will be dropped for both IPv4 and IPv6.
Workaround: Disable both IGMP snooping and MLD snooping.
This sounds very much like what I am experiencing. These switches look very similar from a feature standpoint. Can someone at NETGEAR confirm if this will be fixed? I submitted a ticket as well.
Thanks,
Chad
