Liamcatt
Sep 11, 2017Aspirant
GS748T sfp port issue
Hi We have recently had a fibre link installed between two buildings and I am trying to connect them up however I am having issues with the switches Both are GS748T, and I am plugging the SFP in...
- Sep 12, 2017
Hi,
There can be a few reasons for the fibre connection not working. I have listed 3 common ones below.
1. How far are your buildings apart and what type of fibre are you using (multi-mode or single-mode)? Multi-mode is used for short distances and is the "cheaper" form of fibre modules. Typically, the max distance for multi-mode is 500m (but that can vary). Single-mode modules are more expensive, but have much greater greater range. Often 10-20 KMs. You need to make sure that you use Single-mode fibre modules if your buildings are far apart and you must make sure that you use the same type of module (single/multi-mode) in each end. Look at the manufacturer datasheet for those modules. Are you using the same module type in both ends and are you OK for distance?
2. Have you checked the fibre polarity? You need to make sure that transmit in one end, goes to receive in the other end - and vice versa. Else it won't work. This is important! Try to swap the transmit with receive, in one end.
Like this: http://community.fs.com/blog/wp-content/uploads/2016/06/polarity.jpg
3. Even though fibre is a standard, sometimes certain modules won't work with certain switches. It is just hardware compatibility. This is why Netgear lists official compatible modules in the datasheet, for each switch. That being said, it often will work with different vendor modules, but not always! See here, under the "Modules" section:
http://www.downloads.netgear.com/files/GDC/GS748Tv1/GS748T_ds_03Feb05.pdf
NETGEAR AGM731F (multi-mode)
NETGEAR AGM732F (single-mode)
Cheers
Hopchen
Sep 12, 2017Prodigy
Hi,
Cheers
