IfItAintBroke
Aug 17, 2025Tutor
GS748TR save config locally - only TFTP?
I have an old GS748TR, hardware version 0x3, boot version 1.2.0, and software version 4.0.2.2 that has been running solid for over 10 years. It has now decided (like me) to reboot a couple of times p...
- Aug 17, 2025
What is certainly confusing is the "odd" way (think back on the physics course at school on mechanics and dynamics.
When using the switch WebUI think you sit on the switch itself. Http download is downloading -from- the computer -to- the switch. This you can only download eg. a firmware image or a stored config file -to- the switch. This are all options you have there.
Compare with he options available on the upload option. Here I guess you will find the upload of the text config -to- your computer for retrieving it...
IfItAintBroke
Aug 19, 2025Tutor
Gaaaaah! Thanks for that reminder. I kept seeing upload while thinking download.
Thanks for sticking through this to closure!
