BestYohman
Aug 19, 2024Aspirant
GS748Tv5 managed switch with a Nest pro wifi
I have Nest pros with a Netgear GS748Tv5 managed switch. I have turned off stp and turned on forward BPDU. Everything was working fine until a about a month ago. When I connect the two Nest pros via ...
BestYohman
Aug 25, 2024Aspirant
I updated to the latest firmware. The network no longer goes to a crawl when they both are connected to the managed switch. The max speed I get is 440Mbps when they are connected though. When they are connected to the unmanaged switch I get on average 950Mbps
ErwinL
Sep 04, 2024NETGEAR Moderator
Hello BestYohman
Would you mind providing us the result of your firmware update? How is the status of your network after the update of firmware? I assume your 2nd Nest Pro is also a router. Did you set NAT on your 2nd Nest Pro? What is the WAN or LAN IP of the 2nd Nest Pro?
Have a lovely day,
Erwin
Netgear Team
- BestYohmanSep 04, 2024Aspirant
Sorry I have not had time to try it. Working from home then the holiday...
- ErwinLSep 06, 2024NETGEAR Moderator
Hello BestYohman
That's okay, just keep us posted when you have a chance to provide us update. But I hope to see your update the soonest.
Have a lovely day,
Erwin
Netgear Team - ErwinLJan 06, 2025NETGEAR Moderator
Hello BestYohman
The Christmas season is over, are you able now to provide updates.
Have a lovely day,
Erwin
Netgear Team
