Dakota68
Oct 12, 2016Aspirant
GS752TP Cant ping VLAN IP
I have a switch not currently connected to network, that will repalce an aging switch it has static IP address 10.100.6.225 and have created a vlan 50 which will be for shoretel devices, set up a VLA...
- Oct 18, 2016
Hi Dakota68,
Sorry for delayed reply,
please check if VLAN ID 50 is set as the PVID for ports 1-46 by going to
Switching> VLAN > Advanced > Port PVID Configuration.
The PVID column for port 1 - 46 should say "50" (The VLAN ID for VLAN .50)
Please see more on PVIDs on page 113 here:
And yes, I recommend you create another vlan for servers.
Try that and let us know if it works
Dakota68
sorry meant to say I can ping 10.100.6.225 but not 10.100.50.225 which is the vlan IP, will look at guide you sent
Evans-o
Oct 12, 2016NETGEAR Expert
No problem Dakota68,
And Welocme to the NETGEAR online community!
- Dakota68Oct 12, 2016Aspirant
Thank you, any idea why I cant ping the second IP address plugged direrctly into the swch which is disconnected from the rst of the network? I set up a 24 port first in a differnet builidng and can ping both IP addresses on that one and dont see anything I did differently?
Secondly I am leaving PC's and servers on default vlan of 1, would you recommend I leave vlan 1 alone and create another vlan for servers etc as well as the .50 vlan?
Thanks
- Evans-oOct 18, 2016NETGEAR Expert
Hi Dakota68,
- PeteOct 20, 2016NETGEAR Expert
Also for port 48, you can try to set VLAN 50 as "T" or tagged and leave the PVID as 1.
Hope this helps.
