BilloBaggy
Apr 20, 2022Follower
GS752TP SFP Compatibility
Totally new to fiber, so appreciate any help on this. We're installing data cabinet some distance from our existing wiring closet, and have spec'd a bunch of Trendnet switches (DIN Rail mountable...
schumaku
Apr 25, 2022Guru - Experienced User
The AGM732F is spec'ed as SFP 1000Base-LX SingleMode 1310nm - so if the link is single.mode fiber, and the other end does use the same colour 1310nm, there is nothing stopping you from deploying this config
