jsmith2134
May 30, 2024Aspirant
GS752TP VLAN
I had an old GS752TPv1. It died. I got a GS752TPv3.
So I recreated the VLANS I had.
I can’t seem to connect to the internet with them though.
If I manually set my laptop IP to 10.0.0.x/255.255.255.0, I can ping other machines on the LAN. I can ping 8.8.8.8. But I can’t ping google.com.
Most of my physical ports should be on VLAN 11.
Port 31, 35, 39, 48 are shared across clans.
Port 31 is pinhole which is shared across the VLANs and used to work, I can now ping it from the vans.
Port 48 is my AP and I can access that currently from machines connected to the AP on port 48. I cannot access it from say port 5. My other laptop plugged into port 6 won’t get an IP address.
Port 39 is my Sophos router that is plugged into my modem.
I am sure I have messed something up in the migration but can’t tell what. I don’t remember having VLAN 1 in VLAN Member or Untagged VLANs column.
- jsmith2134Aspirant
