Dakota68's avatar
Dakota68
GS752TP Cant ping VLAN IP
I have a switch not currently connected to network, that will repalce an aging switch it has static IP address 10.100.6.225 and have created a vlan 50 which will be for shoretel devices, set up a VLAN with IP address 10.100.50.227 and IP routing in enabled.
The new switch has a gbic so current media converter will go away, however I have all ports currently left on vlan1 and ports 1-46 Untagged on vlan 50, if I plug a pc into any port 1-46 I can ping 10.100.6.227 but not 50.227, what am I missing? and how should I configure port 48 that will have a shoretel switch on the 50 network connected to it?
Thank you
ProSupport for Business
