PhilaniG's avatar
PhilaniG
GS752TPV2 -DHCP Relay not working
Hi Community,
I have a problem setting up DHCP relay on the Netgear GS752TPV2 switch.
The scenario is this
I have two VLANs, on PC VLAN and One Wifi VLAN. My DHCP server is on the PC VLAN but I also want it to service the WIFI clients.
I've configured the DHCP L2 relay according to the manual but my Wifi clients are not getting IP addresses.
I've manually assigned myself an IP on the Wifi VLAN and everything works fine. I just cant get DHCP working. I also dont see anywhere where you specify the helper address (DHCP Server's IP)
Is this supported in the way I'm expecting or am I missing something?
  • schumaku's avatar
    schumaku
    Configured (and enabled) the DHCP L2 Relay Global Configuration, configured (and enabled) the DHCP L2 Relay VLANs, and configured (and enabled) the DHCP L2 relay interfaces?
    • PhilaniG's avatar
      PhilaniG
      Configured (and enabled) the DHCP L2 Relay Global Configuration - Yes, I've attached a snippet of what I configured.
      configured (and enabled) the DHCP L2 Relay VLANs - Yes, please see attached snippet
      configured (and enabled) the DHCP L2 relay interfaces? Yes.
      I'm using VLAN 1(default) and VLAN 2 (static wifi)
      port 11 (DHCP Server, part of VLAN 1)and port 12 (Wifi AP, part of VLAN 2) have both admin mode enabled.
      furthermore
      Port 11 is untagged on VLAN 1, tagged on VLAN 2
      Port 12 is untagged on VLAN 2, tagged on VLAN 1
ProSupport for Business
