pp6000v2
Dec 01, 2023Follower
GS752TPv2 firmware failure, or hardware failure?
I picked up a used GS752TPv2 that was "tested, powers on." That it does, but I get no connectivity on any ports. I got into the serial console and logged what's happening. With no connectivity, I can not tftp anything. I can send a binary over ymodem to it from the menu, but IDK what I need to do to either save it as one of the boot partitions, or what I need/could do.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.12.01 19:31:11 =~=~=~=~=~=~=~=~=~=~=~=
reset
BOOT Loader Version 1.0.0.5 (2017-12-28 09:35:22 UTC)
CPU : 700 MHz
RAM : 128 MB
FLASH: 32 MB
Model: GS752TPv2
MAC : B0:39:56:BA:E9:FF
Hit Esc key to stop autoboot: 1 0
GS728_752TP_TPP# ?
? - alias for 'help'
base - print or set address offset
boota - boota - boot application image from one of dual images partition automatically
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
env - environment handling commands
erase - erase FLASH memory
flerase - Erase flash partition
flinfo - print FLASH memory information
flshow - Show flash partition layout
go - start application at address 'addr'
help - print command description/usage
iminfo - print header information for application image
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mm - memory modify (auto-incrementing address)
mtest - simple RAM read/write test
mw - memory write (fill)
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
printsys- printsys - print system information variables
protect - enable or disable FLASH write protection
reset - Perform RESET of the CPU
rtk - rtk - Realtek commands
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
savesys - savesys - save system information variables to persistent storage
setenv - set environment variables
setsys - setsys - set system information variables
sf - SPI flash sub-system
sleep - delay execution for some time
tftpboot- boot image via network using TFTP protocol
tp - Mass production TP
upgrade - Upgrade loader or runtime image
version - print monitor, compiler and linker version
GS728_752TP_TPP# reset
CPU : 700 MHz
RAM : 128 MB
FLASH: 32 MB
Model: GS752TPv2
## Booting image from partition ... 1
## Booting kernel from Legacy Image at 81000000 ...
Version: 6.0.0.45
Created: 2018-07-26 17:55:08 UTC
Data Size: 7815870 Bytes = 7.5 MB
Checksum ... OK
Uncompressing ... OK
Starting kernel ...
[A[2K
[A[2K
[A[2Kdal_cypress_construct_phyConfig_init,1039: 0.16 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.17 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.18 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.19 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.20 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.21 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.22 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.23 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.16 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.17 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.18 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.19 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.20 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.21 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.22 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.23 phy enable fail.
unknown rt error code f00f
<3><!-RTK_INIT_FAILURE-!>Init SKI Core Driver Module....FAILED
<3><!-RTK_INIT_FAILURE-!>Init Switch STP Module....FAILED
do_init_module: 'l2g_stp'->init suspiciously returned 557, it should follow 0/-E convention
do_init_module: loading module anyway...
CPU: 0 PID: 116 Comm: insmod Tainted: P O 3.18.24 #3
Stack : 00000000 00000000 00000000 00000000 809f4c3a 00000040 00000074 803a0000
8041d258 86ce1840 80352d18 8039ca67 00000074 809f3d84 8041d258 86ce1840
c13aef48 00000000 803a0000 802c64bc 00000006 8001a590 00000000 00000000
803559c4 86cedd00 00000000 00000000 00000000 00000000 00000000 00000000
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Call Trace:
[<80007dc8>] show_stack+0x84/0xa0
[<80061ac0>] load_module+0x1f04/0x22a8
[<80061f04>] SyS_init_module+0xa0/0x104
[<8000ac9c>] handle_sys+0x11c/0x140
CPU 0 Unable to handle kernel paging request at virtual address 00000000, epc == 8003e298, ra == c00ebf64
Oops[#1]:
CPU: 0 PID: 132 Comm: insmod Tainted: P O 3.18.24 #3
task: 86c6d568 ti: 86cee000 task.ti: 86cee000
$ 0 : 00000000 00000001 00000000 0000007d
$ 4 : 00000000 ffffffff 00000000 00000000
$ 8 : 0000003c 801524b4 ffffffff 803b3d0c
$12 : 810ba414 00000076 00000000 00000000
$16 : 00000001 00000000 00000000 00040000
$20 : 00000001 c1970000 c1970000 00000000
$24 : 8003e280 c00ebe70
$28 : 86cee000 86cef9b0 803a0000 c00ebf64
Hi : 00000008
Lo : 7c1f07c3
epc : 8003e298 down_interruptible+0x18/0x60
ra : c00ebf64 osal_sem_take+0xf4/0x158 [rtcore]
Status: 1000ff02 KERNEL EXL
Cause : 08800008
BadVA : 00000000
PrId : 00019555 (MIPS 34Kc)
Modules linked in: l2g_igmp(PO+) l2g_lacp(PO) l2g_authmgr(PO) l2g_stp(PO) l2g_gvrp(PO) board(PO) ski(PO) osal(O) ksi(PO) net(PO) board_conf(O) max3421_hcd rtdrv rtk rtcore
Process insmod (pid: 132, threadinfo=86cee000, task=86c6d568, tls=77875460)
Stack : 810ba414 00000076 00000000 00000000 ffffffff c00ebf64 803a0000 00040000
00000001 c1970000 c1970000 c1300000 c00ebfc8 86cefa30 00040000 00000001
c1970000 c07a3070 803a0000 c14c0d1c 1000ff03 00000008 80152400 c1970000
803a0000 c14c0d2c 00000000 87c01640 00000020 810ba400 87c02380 00000000
Call Trace:
[<8003e298>] down_interruptible+0x18/0x60
[<c00ebf64>] osal_sem_take+0xf4/0x158 [rtcore]
[<c07a3070>] rsd_l3_adminIntfMgmt_get+0x34/0xa0 [ski]
[<c14c0d2c>] mcast_querier_init+0xf4/0x198 [l2g_igmp]
[<c14add84>] mcast_init+0x84/0x1a4 [l2g_igmp]
[<c1981038>] init_module+0x38/0x90 [l2g_igmp]
[<8000058c>] do_one_initcall+0xf8/0x25c
[<80061a88>] load_module+0x1ecc/0x22a8
Code: 41706000 32100001 000000c0 <8c820000> 1040000c 00000000 2442ffff ac820000 00001021
---[ end trace 35a95f222340d0a4 ]---
Segmentation fault
<3><!-RTK_INIT_FAILURE-!>Init Switch LLDP Module....FAILED
do_init_module: 'l2g_lldp'->init suspiciously returned 557, it should follow 0/-E convention
CPU: 0 PID: 147 Comm: insmod Tainted: P D O 3.18.24 #3
Stack : 00000000 00000000 00000000 00000000 809f4c3a 00000040 00000093 803a0000
86c6d7b8 85873980 80352d18 8039ca67 00000093 809f3d84 86c6d7b8 85873980
c1a96838 00000000 803a0000 802c64bc 00000006 8001a590 00000000 00000000
803559c4 86cefd00 00000000 00000000 00000000 00000000 00000000 00000000
Call Trace:
<3><!-RTK_INIT_FAILURE-!>Init Switch Loop Detection Module....FAILED
insmod: can't insert '/lib/modules/3.18.24/extra/l2g_rldp.ko': Operation not permitted
Segmentation fault
[H[JSegmentation fault
/bin/sh: ?: not found
~ # ls
bin home linuxrc mntusb sbin sys var
dev init mnt modsqfs sqfs tmp webtmp
etc lib mntlog proc sqfs.img usr
~ # ip[J[Jcd bin
/bin # ls
ash diag klogd nstat snmpget
boa dnsdomainname ksid openssl snmpinform
bootklogd echo ln ping snmpset
busybox false ls ping6 snmpwalk
cat fpmd lsmod polld stty
chmod halt mdev poweroff syslogd
chown handler mkdir ps telnetd
cli hostname mknod pwd timed
cp ifconfig modinfo reboot touch
cttyhack inetd modprobe rm true
date init mount rmdir umount
depmod initd mountfs rmmod uname
df insmod msntp sccd usaged
dhcp6c ip mv sh zebra
dhcpcd kill netstat snmpd
/bin # ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default
link/sit 0.0.0.0 brd 0.0.0.0
/bin # reset
1 Reply
- RS80Aspirant
Hello all!
I have exactly the same problem also with an GS752TPv2!
So i connected a TTL-USB converter to the console port on rear side an read with TeraTerm following Bootseq
BOOT Loader Version 1.0.0.5 (2017-12-28 09:35:22 UTC) CPU : 700 MHz RAM : 128 MB FLASH: 32 MB Model: GS752TPv2 MAC : 80:CC:9C:**:**:** Hit Esc key to stop autoboot: 0 ## Booting image from partition ... 0 ## Booting kernel from Legacy Image at 81000000 ... Version: 6.0.6.2 Created: 2021-02-04 17:31:48 UTC Data Size: 11009456 Bytes = 10.5 MB Checksum ... OK Uncompressing ... OK Starting kernel ... dal_cypress_construct_phyConfig_init,1039: 0.0 phy enable fail. dal_cypress_construct_phyConfig_init,1039: 0.1 phy enable fail. dal_cypress_construct_phyConfig_init,1039: 0.2 phy enable fail. dal_cypress_construct_phyConfig_init,1039: 0.3 phy enable fail. dal_cypress_construct_phyConfig_init,1039: 0.4 phy enable fail. dal_cypress_construct_phyConfig_init,1039: 0.5 phy enable fail. dal_cypress_construct_phyConfig_init,1039: 0.6 phy enable fail. dal_cypress_construct_phyConfig_init,1039: 0.7 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.0 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.1 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.2 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.3 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.4 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.5 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.6 phy enable fail. dal_cypress_construct_phyConfig_init,1055: 0.7 phy enable fail. unknown rt error code f030 <3><!-RTK_INIT_FAILURE-!>Init SKI Core Driver Module....FAILED CPU 0 Unable to handle kernel paging request at virtual address 00000000, epc == 8003de18, ra == c00ebf84 Oops[#1]: CPU: 0 PID: 128 Comm: insmod Tainted: P O 3.18.24 #3 task: 8090c5a8 ti: 8093c000 task.ti: 8093c000 $ 0 : 00000000 00000000 00000000 0000007d $ 4 : 00000000 ffffffff 00000000 00000000 $ 8 : 0000003c 80152134 ffffffff 803fba40 $12 : 810b6014 803120ac 00000000 00000000 $16 : 00000001 00000000 00000000 00040000 $20 : 00000001 c1a50000 c1a50000 00000000 $24 : 8003de00 c00ebe90 $28 : 8093c000 8093d9a8 803e0000 c00ebf84 Hi : 00000004 Lo : d39ab280 epc : 8003de18 down_interruptible+0x18/0x60 ra : c00ebf84 osal_sem_take+0xf4/0x158 [rtcore] Status: 1000ff02 KERNEL EXL Cause : 08800008 BadVA : 00000000 PrId : 00019555 (MIPS 34Kc) Modules linked in: l2g_igmp(PO+) l2g_lacp(PO) l2g_authmgr(PO) l2g_stp(PO) l2g_gvrp(PO) ski(PO) osal(O) ksi(PO) net(PO) board_conf(O) max3421_hcd rtdrv rtk rtcore Process insmod (pid: 128, threadinfo=8093c000, task=8090c5a8, tls=77b0a460) Stack : 00000000 00000141 803fb940 00000000 ffffffff c00ebf84 00000000 000c0000 00000001 00000000 c15afe60 c1310000 c00ebfe8 8093da28 00040000 00000001 c1a50000 c07a7620 ffffffff ffffffff 00000000 803fb940 80152080 c1a50000 803e0000 c15a1318 00000000 87c01640 00000020 810b6000 87c02380 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ... Call Trace: [<8003de18>] down_interruptible+0x18/0x60 [<c00ebf84>] osal_sem_take+0xf4/0x158 [rtcore] [<c07a7620>] rsd_l3_adminIntfMgmt_get+0x34/0xa0 [ski] [<c15a1318>] mcast_querier_init+0xf4/0x19c [l2g_igmp] [<c158dda8>] mcast_init+0x84/0x1a4 [l2g_igmp] [<c1a61038>] init_module+0x38/0x90 [l2g_igmp] [<8000058c>] do_one_initcall+0xf8/0x25c [<80061608>] load_module+0x1ecc/0x22a8 [<80061a84>] SyS_init_module+0xa0/0x104 [<8000a81c>] handle_sys+0x11c/0x140 Code: 41706000 32100001 000000c0 <8c820000> 1040000c 00000000 2442ffff ac820000 00001021 ---[ end trace ec21f9d5a702edb1 ]--- Segmentation fault Segmentation fault ~ #Can anybody tell me what's happens?
I have tried to load the FW v6.0.6.2 with "loady" to the flash and save them als runtime1 and runtime 2, but same sh... before...
How can i fix the problem? TFTP is not possible, but all LAN Ports are down.
Regards Sascha
