Tomasz_FLX's avatar
Tomasz_FLX
GS752TS Long reset of Unit 2 switch.
Hellow, Long reset of Unit 2 switch. I have two GS752TS switches in stack configuration. They are connected by SFP Direct Attach Cable AGC761. Unit 1 as Management, Unit 2 as StackMember. Standbay...
  • JohnC_V's avatar
    Dec 04, 2019
    Hi Tomasz_FLX,
    Welcome to our community! :)
    You may need to reboot both switches if you want it to connect again in the stack in order for it to elect its master. This is normal if you just reconnect it while the other switch is running.
    John
    NETGEAR Community Team
ProSupport for Business
