Ahiro
Oct 17, 2016Aspirant
GS752TS SSH connection
Hi everybody!
I got a GS752TS switch and I'd like to manage it remotely using SSH.
But I can't find any information about SSH connexion.
I'm using Putty and it can't connect. I've also looked to the switch configuration : Maintenance => Troubleshooting but I can't find Remote diagnostics option.
Is there a way to manage this switch remotely and if yes, how?!
Thanks for your reply!
Hi Ahiro
Welcome to the community!
You cannot manage a Smart Managed Switch using SSH nor command line. Instead, a Smart Managed Switch is managed used Web interface (GUI) through HTTP.
Command line (CLI) and Telnet/SSH are one of the differences between Smart Managed switches and Fully Managed switches.
If you require SSH over Putty, you should take a look to our excellent M4100 switch series, cost effective L2+ Fully Managed standalone switches here:
http://www.netgear.com/managed
- LaurentMaNETGEAR Expert
Hi Ahiro
Regards,- LaurentMaNETGEAR Expert
Hello Ahiro
For the IP address connected to a port, yes it is possible to detect it using the Web interface (GUI). Please use your internet browser and log into your switch using its management IP address:
1. Use the Port Configuration page to detect the MAC address connected to that port (To access the Port Configuration page, click Switching > Ports > Port Configuration.)
2. Use the Routing VLANs ARP Cache table in order to detect the IP address associated to that MAC address in the ARP table (To display the page, click Routing > ARP, then click the Advanced > ARP Create link)
You will find the GS752TS technical documentation here: https://www.netgear.com/support/product/GS752TS(B).aspx?cid=wmt_netgear_organic#docs
For the FVS336Gv3, this is the same thing: no SSH / command line. You can manage the unit through HTTP (Web GUI).
Let us know how it works with your Port table and ARP table -
