Ahiro's avatar
Ahiro
GS752TS SSH connection
Hi everybody!   I got a GS752TS switch and I'd like to manage it remotely using SSH.   But I can't find any information about SSH connexion.   I'm using Putty and it can't connect. I've a...
  • LaurentMa's avatar
    Oct 17, 2016
    Hi Ahiro
    Welcome to the community!
    You cannot manage a Smart Managed Switch using SSH nor command line. Instead, a Smart Managed Switch is managed used Web interface (GUI) through HTTP.
    Command line (CLI) and Telnet/SSH are one of the differences between Smart Managed switches and Fully Managed switches.
    If you require SSH over Putty, you should take a look to our excellent M4100 switch series, cost effective L2+ Fully Managed standalone switches here:
    http://www.netgear.com/managed
ProSupport for Business
