DF2002
Jan 08, 2020Tutor
Stacking 3x GS752TS steps
Hi, I have a couple GS752TS and one GS752TSP switches, ready to create a 3 switch stack.
I have 4 sets of the direct attach cables as well.
I have logged into each switch, registered them, and updated to the latest firmwares.
I have assigned the GS752TSP switch a static IP and would like to use it as master.
I have assigned the other two switches static IPs as well. Unsure if this is necessary (or even recommended) if stacking them.
I would like to set them up using stacking in a ring topology.
So what are my next steps?......
Do I use ports 51+52 on each switch to create the ring?
What information do I need to configure in the web interface for stacking on each switch?
I have looked a bit for information or guides but can't quite find info for these models.
Thanks for any helpful tips on where I go next!
That's great! You may use the DAC cables for stacking and any of the ports from 49-52 can be used for stacking :)
John
NETGEAR Community Team
- DF2002Tutor
Update: I did find the youtube netgear video which does a nice job of explaining the stacks, albeit with S3300 equipment.
It answered most of my questions.
One thing though, I still am not sure of the exact ports I am supposed to use with the GS752TS equipment. Can I simply use ports 49+50 on each switch using the direct attach cables to configure the stack?
