LBC
Feb 18, 2017Aspirant
Stacking 2 GS752TS via fiber link
I am considering purchasing 2 GS752TS switches to replace our older NETGear switches. The switches are located about 100' away from each other. I would like to stack them via SFP modules and fiber cable. Will this work or do you have to use the stacking cable (AGC761?) which would require the switches to be in the same location.
Thanks
lbc
Hi LBC,
I believe you could use the following SFP modules below to stack GS752TS switches:
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi LBC,
DaneA
- LBCAspirantThanks when looking online I could only find info on using the stacking copper cable
LBC,
You're welcome. :) Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
