hsaartet
Apr 17, 2018Aspirant
4 x GS752TS Stacking
I have 4 x GS752TS and i'm looking to impliment stacking
The user guide http://www.downloads.netgear.com/files/GDC/GS728TPS/GS7xxTS_TPS_HIG_18Jan2012.pdf - Page 28 says i need a AGC761.
But i cant seem to get AGC761 anymore.....whats the suitable replacement?
Hi there
AGC761 is 1Gbps Direct Attach Cable with SFP connectors and it was delivered with each switch in the box. We don't have replacement cable but any 1Gbps DAC SFP-SFP will do.
It is not 10Gbps SFP+ DAC though. SFP+ Direct Attach Cable won't work in 1G SFP port. It must be 1G SFP DAC.
Alternatively, 1G SFP transceivers can be used with a fiber patch cable in between.
- hsaartetAspirant
I contacted a UK Distrbuter whom we have an account with, they said it was no longer avalible
- hsaartetAspirant
in fact, i just searched 3 of these 4 https://www.netgear.co.uk/business/buy/default.aspx#tab-distributionpartners
none have it listed
