hsaartet
Apr 17, 2018Aspirant
4 x GS752TS Stacking
I have 4 x GS752TS and i'm looking to impliment stacking The user guide http://www.downloads.netgear.com/files/GDC/GS728TPS/GS7xxTS_TPS_HIG_18Jan2012.pdf - Page 28 says i need a AGC761. But i...
- Apr 19, 2018
Hi there
AGC761 is 1Gbps Direct Attach Cable with SFP connectors and it was delivered with each switch in the box. We don't have replacement cable but any 1Gbps DAC SFP-SFP will do.
It is not 10Gbps SFP+ DAC though. SFP+ Direct Attach Cable won't work in 1G SFP port. It must be 1G SFP DAC.
Alternatively, 1G SFP transceivers can be used with a fiber patch cable in between.
