drewsandiego's avatar
drewsandiego
2 Stacked GS752TS need High-availibility to stack
Hello, I have 2 GS752TS stacked (SFP) with only one uplink coming from our gateway/firewall connected to the Master switch. I have my servers connected to both switches (LAG), but what if the Master switch dies? What is the best way to make sure if the Master dies my slave has connectivity to the outside network? Options I have come up with:
  1. Provide a second uplink from the gateway/firewall with some config on the firewall so it's on the same sub as the original uplink.
  2. Insert a smaller switch to split the one uplink into two.
  3. Some magic config on the GS752TS.
Thank you in advance for any and all assistance!
  • JohnC_V's avatar
    JohnC_V
    Nov 22, 2017
    drewsandiego,
    You're very much welcome! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi drewsandiego,
    Welcome to our community!
    I may agree to the first and second option that you have that you may connect 1 switch to the router and also the second switch goes to the router. The 2nd option will also work as long as the smaller switch that you have should also support STP/RSTP to avoid loop inside your network.
    • drewsandiego's avatar
      drewsandiego
      Thank you JohnCarlo. I appreciate the good advice. I think option 1 will be the way I go. We've been looking at getting a new firewall anyhow.
      • JohnC_V's avatar
        JohnC_V
        drewsandiego,
ProSupport for Business
