drewsandiego
Nov 21, 2017Aspirant
2 Stacked GS752TS need High-availibility to stack
Hello, I have 2 GS752TS stacked (SFP) with only one uplink coming from our gateway/firewall connected to the Master switch. I have my servers connected to both switches (LAG), but what if the Master ...
- Nov 22, 2017
You're very much welcome! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Nov 22, 2017NETGEAR Employee Retired
Hi drewsandiego,
Welcome to our community!
I may agree to the first and second option that you have that you may connect 1 switch to the router and also the second switch goes to the router. The 2nd option will also work as long as the smaller switch that you have should also support STP/RSTP to avoid loop inside your network.
- drewsandiegoNov 22, 2017Aspirant
Thank you JohnCarlo. I appreciate the good advice. I think option 1 will be the way I go. We've been looking at getting a new firewall anyhow.
- JohnC_VNov 22, 2017NETGEAR Employee Retired
