drewsandiego's avatar
drewsandiego
2 Stacked GS752TS need High-availibility to stack
Hello, I have 2 GS752TS stacked (SFP) with only one uplink coming from our gateway/firewall connected to the Master switch. I have my servers connected to both switches (LAG), but what if the Master ...
  • JohnC_V's avatar
    JohnC_V
    Nov 22, 2017
    drewsandiego,
    You're very much welcome! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
