hsaartet
Apr 17, 2018Aspirant
4 x GS752TS Stacking
I have 4 x GS752TS and i'm looking to impliment stacking The user guide http://www.downloads.netgear.com/files/GDC/GS728TPS/GS7xxTS_TPS_HIG_18Jan2012.pdf - Page 28 says i need a AGC761. But i...
- Apr 19, 2018
Hi there
AGC761 is 1Gbps Direct Attach Cable with SFP connectors and it was delivered with each switch in the box. We don't have replacement cable but any 1Gbps DAC SFP-SFP will do.
It is not 10Gbps SFP+ DAC though. SFP+ Direct Attach Cable won't work in 1G SFP port. It must be 1G SFP DAC.
Alternatively, 1G SFP transceivers can be used with a fiber patch cable in between.
hsaartet
Apr 19, 2018Aspirant
I contacted a UK Distrbuter whom we have an account with, they said it was no longer avalible
hsaartet
in fact, i just searched 3 of these 4 https://www.netgear.co.uk/business/buy/default.aspx#tab-distributionpartners
none have it listed
- schumakuApr 19, 2018Guru - Experienced User
LaurentMa - suggestions? Any alternate modules compatible?
- LaurentMaApr 19, 2018NETGEAR Expert
Hi there
- hsaartetApr 19, 2018Aspirant
been told to use AGM731F plus fibre cables
i'm trying to find out if this would give the same advantages as stacking
Yes, you will configure the SFP ports as "Stacking Ports" and form the stack the same way.
Regards
