Ahiro
Oct 17, 2016Aspirant
GS752TS SSH connection
Hi everybody!
I got a GS752TS switch and I'd like to manage it remotely using SSH.
But I can't find any information about SSH connexion.
I'm using Putty and it can't connect. I've a...
- Oct 17, 2016
Hi Ahiro
Welcome to the community!
You cannot manage a Smart Managed Switch using SSH nor command line. Instead, a Smart Managed Switch is managed used Web interface (GUI) through HTTP.
Command line (CLI) and Telnet/SSH are one of the differences between Smart Managed switches and Fully Managed switches.
If you require SSH over Putty, you should take a look to our excellent M4100 switch series, cost effective L2+ Fully Managed standalone switches here:
http://www.netgear.com/managed
LaurentMa
Oct 17, 2016NETGEAR Expert
Hi Ahiro
- AhiroOct 17, 2016Aspirant
Thank you for your reply LaurentMa!
That's what I thought...
I wanted to watch the ip address connected to a port. Is there a way to do it without CLI then?
Oh and... I wanted to buy an FVS336v3 firewall. Can we manage it with SSH? I can't find any information on it...
- LaurentMaOct 17, 2016NETGEAR Expert
Hello Ahiro
For the IP address connected to a port, yes it is possible to detect it using the Web interface (GUI). Please use your internet browser and log into your switch using its management IP address:
1. Use the Port Configuration page to detect the MAC address connected to that port (To access the Port Configuration page, click Switching > Ports > Port Configuration.)
2. Use the Routing VLANs ARP Cache table in order to detect the IP address associated to that MAC address in the ARP table (To display the page, click Routing > ARP, then click the Advanced > ARP Create link)
You will find the GS752TS technical documentation here: https://www.netgear.com/support/product/GS752TS(B).aspx?cid=wmt_netgear_organic#docs
For the FVS336Gv3, this is the same thing: no SSH / command line. You can manage the unit through HTTP (Web GUI).
Let us know how it works with your Port table and ARP table -
My Routing VLANs ARP Cache is empty.
Is it normal and if yes, how can I tell the switch to fill it up?
When I go to Switching > Ports > Port Configuration, every port got the same MAC address too...
