Semaphor
Sep 25, 2022Initiate
GS752TXS no reaction after FW update
Hello. I got today a GS752TXS with an old Firmware (FW-V5.2.0.20), thus I made an update to the latest Version (gs7xxtxs-v6.1.0.39.stk) with the procedure described in the "gs7xxtxs-v6.1.0.39_Releas...
DaneA
Sep 26, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
The GS752TXS firmware v5.2.0.20 was the initial firmware release. The best approach for updating the firmware to the latest version is to do it in a ladderized manner wherein update the firmware from v5.2.0.20 to v5.2.0.26 then, from v5.2.0.26 to v6.1.0.27 and so on until you reach the latest firmware which is v6.1.0.39.
Based from what happen as you have described in your initial post above, the GS752TXS got bricked since both the power LED and the port LEDs are just lit up orange and unresponsive even after doing several factory reset & powercycle. Thus, the switch needs to be replaced.
DaneA
NETGEAR Community Team
Semaphor
Sep 26, 2022Initiate
Hello DaneA.
Thank your for your quick reply.
It's a kind of strange that nothing went wrong during the FW update but it ends in a desaster
and it's even more strange that it still show's some traces of life, but there shall be no way to get it back to full functionality.
I still wonder if I didn't notice a hind to update step by step or if there was none,
But anyways I need a solution for my situtation and it seems I have to go the hard way and buy a repalcement
Regards
Martin
