das2017
Jul 06, 2017Aspirant
GS752TXS Vlan setup
Hello, I have four GS752TXS switches stacked using the SFP ports 51 and 52 on each switch. Everything works fine. Now, I'm trying to set up at least two VLANs and are wondering what's the best ...
Retired_Member
Jul 06, 2017Hi das2017,
Welcome to the community!
We need more detailed information as below:
At first, would you please provide your network topology?
Second, which device working as DHCP Server for two VLANs? Firewall or Router?
Typically, we suggest setup network as below:
EricZ
NETGEAR employee
das2017
Jul 07, 2017Aspirant
Hi Eric,
Although I don't have a diagram, it's pretty similar to the one you posted. I have a router (which, to answer your second question, is also the DHCP server) connected to port #2 on switch #4 in the stack.
Based on your diagram, I would have to configure the VLANs in the router as well, correct?
Would I also have to tag the port the router is connected to (port #2 on switch #4) to all the VLANs I set up?
Thanks again
